A
atifkt
Banned
Thanks.
Cant monitor myself during recordings. This is what I'm doing. I use audacity to record.
My headphone has a 3.5mm jack so I have to use an adapter to connect it to the interface.
I turn the monitoring button on and turn the knob to max. Now when I press record the instrumental can be heard fine , My voice is recorded but I'm not able to hear myself.
A solution please?
It is due to the dynamic mic. Most dynamic mics need a lot of gain and you would typically turn the gain knob all the way up. It is not because of the windscreen.Ok So it's working but I can only listen myself when I turn the gain knob to max.
Wh-wh-what adaptor???I guess its due to the adapter and the windshield on my dynamic mic.
Why do you have an adaptor?? Your mic should have an XLR jack and you should be using an XLR cable.Btw the monitor knob on the front. What is its use? I turned it to max. and min. and there was no difference.
Your record with shit, you get shit. Now to the issue. The Focusrite 2i2 is not a magic box. It is transparent. That means it will not "color" your mix. It cannot make a mix "better" Your tracking is your problem. First try talking with your hands away from your face then slowly bring your hands you the heels of your palms together in front of your mouth and your fingers poited back toward your ears creating a scoop to move the sound back to your ears. See how much better your voice sounds? That's presence and clarity. Not work on your mix to get that clarity and presence. I'm not going to give you the frequencies to cut, just work around until you find it (My speakers are not your speakers). Did you notice how much better your mi sounded when you dropped out the background? Copy and paste that section into a new project and get it right. Then go back and clean up the sound on the back ground so it doesn't pile up[ too much on the low mids. The easy way is just to add a BBC Sonic Maximizer and add in a little mid-top. That unit does wonders for dull mixes or old tapes. I hope this helps. Rap is not as demanding as jazz vocals but because of that it can also become a little heavy in the low mid area. Start there. Good Luck.
atifkt...
Unless you have a strong breeze blowing near your microphone, get rid of the foam windscreen on your mic. It may be part of the reason your sound is sort of muffled. Instead of the foam try making a pop filter which will make the sounds more open and may improve clarity......
DIY Microphone Pop Filter - YouTube
It will also help you keep a proper distance from the mic to avoid the proximity effect which can effect the boominess or thinness of your voice. Try different mic distances to see what works to get where you want.
You had said the mic you have is an Indian brand mic. Any chance you have link to the specifications?
Not sure how your Focusrite 2i2 works and maybe someone familiar with the 2i2 can help out, but ideally you should be able to use headphones to hear the music track plus your voice when tracking the vocals. Your Youtube video kind of hinted that you don't use headphones while tracking and I'm wondering if the music backing track your singing to is through monitors/speakers which isn't really a good way to do that as the mic will mix some of the music back into your vocal track.
The mic I have without the windscreen gives a lot of pop sounds.
Use or make a pop filter.
They're much more transparent than a foam ball on the mic.
Just for the sake of mentioning it, I often use the heavy foam head with the sm7b and have no problems, but still, I can't say it's bad advice to try a pop filter.
Are the microphone specs good?
Funny you mention the PL24. I Bought one of those on a MF Stupid Deal of the Day.
You dont have an omni Chili?
Dude you need to try an omni on an acoustic guitar.
His mic.....
Microphones >> Performance Series
PRO+ 3200 : Supercardioid Dynamic • Pro-Entertainment + Studio
