John Sayers
Solar Power!!
Chris - firstly - Dave Moulton is ONE idea about control room design - He's saying that the sound that goes to the rear should reflect back at you
I say it definitely shouldn't unless your rear wall is over 9 ft from you - in other words it works for large rooms (in a way) but won't work in small rooms IMO.
Slots and Panel absorbers will absorb below 800hz but hey good rigid fiberglass insulation like 703 will absorb down to 250 hz which is far superior to that crappy foam stuff
and as Tex said you have to lift it well off the wall to get any lowering of the absorption frequency.
next time you are at your speakers try cupping your hands up behind your ears to stop the rear sound - you'll hear a definite improvement in imaging etc.
cheers
john
I say it definitely shouldn't unless your rear wall is over 9 ft from you - in other words it works for large rooms (in a way) but won't work in small rooms IMO.Slots and Panel absorbers will absorb below 800hz but hey good rigid fiberglass insulation like 703 will absorb down to 250 hz which is far superior to that crappy foam stuff
and as Tex said you have to lift it well off the wall to get any lowering of the absorption frequency.next time you are at your speakers try cupping your hands up behind your ears to stop the rear sound - you'll hear a definite improvement in imaging etc.
cheers
john
