The fact is that with audio devices it rarely ever comes down to a choice between the two, unless the capabilities of the two devices one is comparing are wildly desparate in other ways.
And in those few cases where there is a choice between similar capability devices, one that uses FW and the other that uses USB, there are usually far more important differences elsewhere; you know, little things like price, quality of preamp, etc.
It's really IMHO a non-issue. I have used several devices on both FW and USB, and never has the interface type been an issue of any type whatsoever except among tweakheads and pocket protectors who get off debating such issues.
The weakest point in the whle issue might, *MIGHT* be if one is using a USB device and they are concurrently using USB for several other devices simultaneously. Just to be in the safe side I would not recommend carrying that to an extreme.
But even then there is usually plenty of designed bandwidth overhead to go around, and stuff like buss interrupts have not been a problem for me. I've run a 2GHz Celeron laptop (no screamer by any standard today) with a USB mouse, USB keyboard, and USB external CD/DVD burner connected simultaneously with a Tascam us122 USB audio interface with two channels of phantom-powered mic preamp running. We ran this setup on a location recording for over 8 hours without a single hiccup or even indication of a chance of a hiccup anywhere. Now granted I did not try recording and burning simultaneously, but I'd recommend against that regardless of interface type.
Fuggedaboudit
. It's not worth losing sleep over, IMHO, unless the number of available ports one actually has is an issue.
G.
