B
boingoman
sosob said:Define "loud"...does it mean when your ears hurt from adding too much volume on the EQ?
Using an EQ in this manner will only make your production one-dimensional,noisy and fatiquing to the ear - i mean..where does using an EQ actually stop?.If they're a "loud" group it should have been tracked/mixed loud then you would only need slight compression to achieve ultimate loudness.Yes, you do need a vacation.
No need to get sarcastic.
Loud in this case means average level as high as possible.
And no, you can't just get that from loud tracking and some light compression. It takes lots of brutal compression, and most likely lots of EQ cutting, not boosting.
Most times, EQ is used to cut, not boost, just so's you know.
