Track Rat
Just Your Average Sized Member
Here's a thought, learn to play without the squeaks. Nothing goes on my strings except my fingers, sweat and the occassional spilled beer and a little drool.
Read up in the post ya dork. I mentioned Finger ease.
Track Rat said:Gorilla Snot is a tacky substance that drummers put on sticks for traction and guitar players on their picks so they won't drop 'em. Finger ease is the revolting slime I've seen guitar & bass players spray on their strings to eliminate squeeks. I picked up a guy's guitar once that used that shit and it was like putting your hand in a lung cookie. Very nasty.
malgovert said:
Well... to be fair, Fangar, you did call it Fanger Ease...![]()
But I take your point about the goofy applicator... What's Fast Fret anyway? It sounds a lot cleaner than Gorilla Snot... I like the idea of teflon spray too... what about a pair of rubber gloves to boot??? Learning toplay without the squeaks - well that sounds like a lot less fun...![]()
Malg.
. Anyway the premis behind finger (Fangar) ease is this. It is said that when you change a set of strings that if applied, finger ease fills in the spaces between the strings with a light coating that helps to keep the dead skin from your Fangars from building up in there. If you apply it, you need to wipe off the excess so that it is not all snotty like the RAT said. It is also siad that when you put it on old strings that it coats the fangar sluff in the strings. Bad I guess. Anyways, Gorilla Snot is for picks and Sticks, which are often dropped due to bad technique. Anywho...fenix said:
Fast fret is the bomb. That's what is it. Finger ease is the generic version of fast fret.
fenix said:
Fast fret is the bomb. That's what is it. Finger ease is the generic version of fast fret. and no, it does not have a goofy applicator...perhaps you were referring to yo mama's tampons. j/k.
malgovert said:what's the best way to eliminate 'fretscrape' when recording acoustic guitar? I have tried every mic position under the sun but it's still picking it up. I'm using a Rode NT3 and/or AKG cs1000.
Thanks - Malg.
Jimmy D. said:I've had good luck with Elixer (sp?) strings - that coating (or whatever it is) seems to minimize the 'creaking', and actually had a secondary effect of warming up the recorded sound of my guitar (Taylor 410 - pretty bright sounding)...
Anyway, I hope this helps! -
By the way - these strings seem to have a little longer life than the D'addarios I was using..
Jim
