You will also need to connect SONAR and the MPC by using MIDI.
MIDI OUT of your computer to MIDI IN on the MPC.
You will need to set the MPC to receive Midi Time Code [MTC] on the appropriate MIDI IN.
You will need to tell SONAR to transmit MTC. You will also need to tell SONAR which MIDI OUT to send the MTC.
On the MPC...
The MPC sequence can be off any length with Loop OFF and just using the MPC main outputs.
Setup Sync on the MPC:
Press SHIFT+9 (SYNC) on the MPC.
Set your SYNC IN. Set to 1 or 2 (depending on which MIDI IN you are using).
For MODE set Midi Time Code with Frame Rate: 30
Receive MMC does not matter since you are not setting SONAR to send it .
On the right side set Sync Out (Out: B)
Set Send MMC: ON..
In SONAR...
1. You'll need to set the TEMPO
2. You'll need to set up Sonar to transmit MTC.
OPTIONS>PROJECT>SYNC>SEND MIDI TIME CODE>check mark TRANSMIT MTC
I would also.... add two blank bars to the beginning of the sequence on the MPC (this is necessary to give the machines time to lock into the midi time code signal).
Highlight BARS: on the MPC main screen and press open window.
On the left side, set After Bar: 0
Just below, set Number of Bars: 2
Press INSERT.
This should get you up and running.
If you have any other questions, post it in the Hip-Hop Forums (sometimes I don't check this forum daily).
Peace...
spin
https://homerecording.com/bbs/showthread.php?s=&threadid=113572
