spitzer
To rob aylestone and witzendoz in particular:
I realise some of my replies to you have been blunt and seem harsh (even if you didn't feel that way I still wanted to say this, because it might look different to a 3rd party). That was all on purpose. I might have said this even earlier, but I simply want to be clear and straightforward and just plain sort it out to minimise the misunderstandings multiplying over time. We've already noticed sort of the thing where it's getting confusing like witzendoz said: someone mentioned something and then someone else thought I was considering doing that.
Also I again want to stress that to me, this is not a debate and what I mean by that is that my intention is not to prove this or prove that. For example the cardboard box thing I keep bringing up is not supposed to be this or that in itself, it is part of the process of figuring out "well if I do this and it works like that, probably the same principles apply to..." You know? I do accept alternate theories and I certainly always accept the truth. What I do NOT mean by that is that "I'm always right." Please. Please understand this. No, I can be wrong about a lot of things. If that is the case, I really wish you would point that out specifically and explain what is wrong.
There's also the loss of focus effect in ignoring "correct" sentiments and instead pointing out something else (usually small and beside the point) that's "incorrect". Saying I misused the term "flanking" and that I don't understand the detailed mechanics of how wall plugs work while at the same time not acknowledging at all that the cardboard box barrier worked is an example of this loss of focus. As far as I can tell, so far no one has refuted that it did in fact work. That is so much more interesting than anything else being discussed at that point that it's not even funny. Do you think it did really work? Do you think it was an illusion of some sort? How do you explain why it worked the way it did? Should I have specifically pointed out that because that worked, I think a larger device of similar construction would also work in a similar fashion? To me, it was obvious that this small-scale experiment is linked to my plans for the wall or large panel, and not just some random thing I decided to post here to confuse people. Why would I do that?
To me there is this odd disconnect: The site is called Home recording, which to me does not suggest academic, esoteric, difficult stuff. On the contrary, I think the default assumption should be that people have NOT read 700 page books on mechanics, aerodynamics and material technology. Who records at home? Probably an amateur musician. Are they likely to invest the time and money and have the knowledge and skills to build a top of the line professional level recording studio? Are they likely to even try to do that?
