T
TaxMan88
Is there a sort of "virtual effects unit" out there that supports VST and DirectX plugins? Here's what I'm thinking:
This would be a program that you could sync up to another program such as a multitrack recording program. It would be a stand alone program, but would work in conjunction with the program you're tracking in. Say for instance you're using a multitracker that doesn't support plugins, you could sync the "virtual effects unit" up to your multitracker software and export the track you'd like to add effects to. Then, when you playback on the multitracker, the "virtual effects unit" would play back as well, but WITH the effect on the track you sent so that you can get a real time indication as to what it sounds like?? Then, once you're happy with the effects you've applied, send the track BACK to the multitracker and you've got happiness.
I'm sure this has got to exist out there SOMEWHERE! Someone please enlighten me on this one.
--Tax
--Tax
