Anfontan
Banned by eurt
Seems like you are playing fuller chords that most people would play with heavy distortion. Try for sparser chords like the root and 5th and it should beef up the tones quite a bit.
There's nothing muddy about that clip. You've said that before about stuff that is ear piercing with high end. This one is not as bad as some of the ones you've done. You need to start looking at your monitoring situation. Or you could have hearing loss.
Eck,
Why not try a stomp box on your clean channel? If you can't get the amp's effects to do what you need, out-source!
And I'd see about getting an SM58...![]()
to me, three things stick out with yours
Source Tone
Mic Selection
Mic Positioning
PS: Stating the obvious
The mix doesn't help much, to me.
I, personally, could never capture a good guitar tone using a Firepod. When I owned it, my guitar tone always came out really thin and grainy. It had no warmth or fullness to it.
I doubt it. You can still get a great sound with bad preamps. Only thing, it'll be better with good preamps. With the right source, mic(s), room, and positioning, you could get a great sound with behringer preamps. Firepod pres are much better than behri!Do you think the firepod preamps are that bad that they would contribute to my bad guitar recordings?
What are you using now?
Any chance I could hear some of your recording with your new gear?
Thanks man,
Eck
I agree with you on the source tone, and maybe mic selection aswell, although the Beta52A is a cracking mic, even if it is meant for bass instruments.
That mic sounds great on toms, compared to the likes of an SM57 or 58 btw.
I tried every possible mic position pretty much. I learned how making the tiniest change in mic position can make a great change in tone.
I was moving the mic by baw hairs at a time! And I could hear every change in each recording.
At least Ive learned something from trying to get a decent hard rock/metal tone from a Marshall.
Thanks,
Eck
I'm not sure what you're looking to get from this.
I'm slowly coming to the conclusion that my amp sucks ass!
Yeah, the firepod has good budget pres.Yeah, I think Firepod pre-amps are good enough to get better results that Ive been getting for guitars.
I mean I've used a Yamaha 02R96 desk with SM57/58, AKGC414 etc. And had worse results with my guitar tones!
Cheers,
Eck
I probably agree the source tone could be an issue.
Speaker?
Are you dialing the amp and adjusting the mic position while reamping and monitoring with your studio playback setup?
maybe this amp's just not the best for a complex saturated tone to be out front.
MIght give your suggestion a go though, never really liked the idea of remping but I suppose it could help to get closer to a decent sound.
Thanks man,
Eck
