delta 44 for n-track
  • Thread starter Thread starter Roy/Keys
R
Roy/Keys
I am thinking about buying a delta 44 soundcard for use with my n-track. Any comments, pro or con ?
plenty of folks here using the delta series would recommend the rig.
I used an AP and a 66 for a few years and they did a fine job.
The only problem with mine is that it only has 4 inputs.
And now I have 5 mics
4 ports
Well at least it should do to get me started, then I can upgrade later, I guess.
For the small difference in price, I would get the 66 instead. In fact, some UK stores sell the 44 and 66 at the same price.
The 66 adds s/pdif i/o on rca-coax (no optical). Otherwise, AFAIK, it's identical to the 44.
You never know when you might need an s/pdif!
And s/pdif helps to sync two soundcards together for when you get another.
2 x Delta66 (giving 8track record) cost less than 1x Delta1010.
