punkin
Univalve & Avatar Speaks
Many of you are aware that I'm a big fan of the Delta 1010LT product. Big bang for the buck but I think I may have a problem. Tell me what you think.
I recently clean house...got rid of some cheapie toob pre's and cleaned up some cabling which was abandoned inside and behind my console. I'm guessing you're likely to dwell on this...righfully so but hear me out.
I got a little carried away and went into a neat freak frenzy. I pulled everything out, dusted out the gear and put things back together. I have a couple 1/4" patch panels into which all my audio source outputs are plugged into (mic pre's, DI's, mixer channel inserts and such). Then, I have a couple patch panels for the recording DAW inputs (I've got more than one DAW and audio interface...I'll spare ya).
Today I went to set up for a small combo session I've got scheduled for this weekend. I was planning for 8 simultaneous channels. All looks fine except for channels #7 and #8. With two seperate mic pres patched to #7 and #8, hit record arm and both channels immediately register about -24 on the VU. Remove the patch cord from either channel and the remaining patched channel looks ok and records just fine. I can reverse the channels (use either channel or either mic pre) and the result is the same, I simply cannot use both DAW channels at the same time.
I looked into the Delta Control Panel to make sure something wasn't patched over in there but not. Again in the Delta Control Panel, when this thing is acting up, it things that there is a lot of audio being supplied to the input when there isn't any.
Sorry for the long post...any thoughts? Help me before I pull out that one last hair and let me tell you...it ain't on my head
