Interesting ' problem' with my Tascam DP-02
  • Thread starter Thread starter TascamJimi
TascamJimi
TascamJimi
Member
Hey folks, I've come here with some really silly questions..... that have been answered and not laughed at so....going to try another one....and this is definitely a strange one...
I recently recorded an arpegiated ( sp?) guitar line that last about 4 minutes....upon playback, at about the 2 minute mark, it starts to slow and go out of tune... sounds exactly like batteries dying in a tape deck...very strange..... as a test, on another track I recorded the same pattern, just using a looper pedal instead of playing the part straight through to eliminate poor picking technique the longer I played......... it does the same thing...starts out fine... then all of a sudden it starts ' dragging' and going out of tune with itself. I know that technically this is impossible with digital..... (or is it ?. )......... but my ears are telling me otherwise.... no modulation effect on the guitar...just bone dry....so I ruled that out....and it's just a single guitar line ...not doubled or anything...
Has anyone ever experienced this ? I have a 5 track sub-mix on tracks 7/8 and they play fine, all the way through.... I can't figure this one out...
The timing will all come from a quartz crystal, so it ought to be accurate.
I was once told that over a long time they are accurate, but can wobble about a bit.
They are actually electrical/mechanical oscillators, and may operate in more than one mode due to geometry.
The only other thing I can think of is how the sampling frequency gets divided down.
It may involve spikes instead of square waves, which may not register at times.
I don't have a DP02, but I've never experienced that with any of my digital recorders (2 Yamahas, 2 Zooms, 1 Tascam interface).
Is it a gradual slowdown, or an immediate change, which might indicate a change in sample rate happening somehow?
@Slouching Raymond That was interesting. Went straight over my head but.... I'm going to Google what you mention and see if I can get more information....this unit is indeed 20 years old so age might be an issue.... I just find it odd that the sub mix plays fine..... but the arpegiated part is slowing down...
@TalismanRich It's pretty abrupt... definitely noticeable... maybe over the course of a measure or two ...You can definitely hear it happening when it starts....I'm going to add another guitar part on an adjacent track , played the same way..... just too see what happens....It would totally baffle me even more if that track plays fine !!
I know it's a total long shot ( again considering my sub mix on 7/8 plays fine ) but lately it's been getting really hot in that room..... 85 + degrees.... wondering if that might be an issue...I crank the a.c.,when I start working....... but maybe the unit was struggling while actually RECORDING the part and now it's just stamped on there and it's actually not a playback issue...
This one really has me stumped... I even asked a friend to listen to the track w/o saying anything.... and he picked up on it as well.... ' Why does it sound like your batteries are dying ?' !! I sure find / have some very strange issues with home recording !! Still love every minute of it...
As always , THANK YOU for trying to help out..... This forum has helped me tremendously in getting back into recording.
Can you post a short section where the timing changes? If you render to a file, is the tempo/pitch change apparent on playback?
I doubt that temperature is an issue... most electronic gear is good at normal temps. A DP02 should function perfectly fine at 85 or 90 degrees. People do onsite recordings outside in the summer all the time.
@TalismanRich Rich, sorry it's taken so long to get back to you. I decided to step away from that project for a little bit.... I wasn't getting anywhere with it but frustrated !! LOL... I didn't want to leave anybody hanging here as I've gotten a LOT of help from you folks. I'm grateful.
Raymond mentioned the Crystal - All digital devices have a clock. this keeps the sample rate locked. So if it is 48,000 samples a second, it doesn't change. If that slowed down, or speeded up, the pitch would indeed change. Some effects units actually do this kind of thing to make weird stuff happen. They use little bits of crystal that oscillate at a precise frequency and do some maths on it. If you started two digital machines playing the same audio file at the same time - say with drums. They'd be in time, but after and hour or two they might be slightly out. An old fashioned tape machine struggled to stay together for the length of a single! If you ever get a chance to post a clip - we could analyse it and report back.
