carlosguardia
Here's a Q for a few of you that I believe are using the SBLive with another sound card together. The question, as most of my questions, might be a silly one with a quick and easy answer but here it is nonetheless:
I just plugged in my 1010LT, installed the software etc... however, I still have my SB Platinum Live and wish to continue to use it. I use the optical out of the SB to connect my Roland DS-90 monitors plus I use the Aux in 2 in the "front panel" to connect the audio outs of my Roland midi module and I want to continue to use the SB for soundfonts... now, the problem is that I cannot monitor what I am recording in Sonar 2.0 unless I go to Options>>Audio>>Input monitoring and select the inputs I want to monitor... which for some reason sounds screwed... it doesn't sound nice at all.... anyways... what can I do??!!!!!!!
HELP!!!!!!!!!!!
Carlos
HELP!!!!!!!!!!!
Carlos
anyways... I tried to connect
) must be set to output through the SPDIF output. If windows can handle it, then Sonar shure like hell can!
