Paul881
Look Mom, I can play!
Picking a good graphics card IS driving me crazy - too many variables to think about. I don't play games but do use it for video and power point sync work with Sonar. And I do intend to have two monitors, so it needs to have a dual DVI output. Minimum 256 Meg memory and be AGP compatible.dachay2tnr said:Do you want a card for a single monitor or dual monitors. Will you use it for gaming, or any other graphic intense applications?
In my DAW I use a dual monitor Jaton Geoforce 2 Twin, something like this one:
http://www.newegg.com/Product/Product.asp?Item=N82E16814139149R
It is nothing special, but works and is an AGP type card. I have two CRT monitors hooked up to it. I paid $58 for it a couple of years ago, and I see it is now like $30 cheaper. It only has VGA connections. You might want one with digital outputs (DVI?) for an LCD monitor.
In my internet computer I am using an XFX card (nvida chip). Again it is nothing special, and also AGP. I wouldn't recommend it for gaming, but is fine for me. I paid around $35 for it, but it also does not have a DVI port. Just VGA. My LCD monitor, however, will take either VGA or DVI, so I simply use the VGA to connect it.
Picking graphic cards can drive you crazy, as they run from $20 to $500. If all you are going to do is word processing, internet browsing, and Sonar, I would go for something cheap. Just make sure that the card's highest output resolution matches (at least) your monitor's resolution. LCD's don't look good except when they are run at their native res. If you truly got a wide screen monitor (16 X 10 aspect ratio), make certain the card is capable of outputting that resolution.
I never gave a thought about a card not being suitable for wide-screen until you mentioned it - I had just assumed it would work okay, so thanks for mentioning it
I will investigate some more, later today.
