Jeff_D
Anomaly Design said:... I tried testing them, speaking into and everything, volume levels bla bla and they work fine. They just refuse to record anything. Anyone have any ideas/things I should try?
So your getting signal from the mics, through the Firepod and out to your monitors. Yes?
Make sure you have the correct source selected in CEP and make sure you have the track armed to record. I'm not familiar with the Firepod, but if its like most other interfaces, it has some type of software control panel- yes? (i.e. like the M-audio stuff has the Delta Control Panel). Make sure nothings muted or clicked in there that may prevent your signal from reaching CEP- try plugin the mics into a differnt channel and recording them - try differnt mics in the same channel (lets isolate your problem)
Also, these are overheads for the drums? What type of mics? are you sure they're not recording- but just at a really low level (since your mouth is alot closer than the drums Im sure your checking maybe misleading) maybe you need to turn up the gain? Are they condensor mics? Is phantom power supplied ( im guessing thats not the prob cause you said they work otherwise)
