D2424LV - Track Naming??
  • Thread starter Thread starter Rock God
R
Rock God
Hi,
I've just upgraded my D-108 to the D2424LV, I love it so far...most of the little changes I'd have liked in the D-108 have been put in. Track naming is one of them but I can't find a way to view the names other than in the track name edit mode in setup. Does anyone know if the names can be viewed through an easier method?
Thanks
Just use the program select [PGM SEL] button and the jog dial. ( see page 37 in the manual )
Thanks for the reply John but that method only shows the program titles, not the individual track names.
D'OH!!!! I hate it when I think I'm like smart or something and I actually just didn't comprehend the question correctly!! Sorry about that.
I only named all the tracks in a song once and it was so much work I didn't bother with it again. ;-)
It would be nice if there was a way to hold down a special key and then press the track arming buttons to see the track name or something but I don't think they have that feature.
How about going into the Edit menu then Track Exchange Mono. You could then spin through the tracks with the jog wheel and see their names. ( I haven't tried this . . .I don't think . . . ) See page 75 in the manual.
Best of luck!
John L Rice
Drummer@ImJohn.com
Yeah, the track naming takes so long it's probably easier just to remember where everything is!
It'd be great if they could make it easier to view the names with a software update, shouldn't be too difficult.
Yeah, I had the same idea about using the 'track exchange mono', I think it's the best way to do it at the moment.
I can name the programme titles very easily through my computer with the ethernet connection but it won't let me rename the tracks as anything but "trxx.wav".
Just a small problem though, I'm still very happy with the recorder.
Thanks for the help John!
So, what all can you do with the ethernet connection? I don't have it on mine. Does it come with special software?
Thanks!
With the ethernet connection the 2424LV becomes an actual server with an IP address. I can firstly send the tracks to my computer directly, process them and send them back, but I can also access the recorder from anywhere with an internet connection with the IP, username and password of the Fostex.
They added a new software version when they installed the card at the factory which lets you set the IP address, user name etc. I think it's available from the Fostex site if you want to buy the ethernet card and install it yourself.
I was just snooping around the Fostex sites for new D2424LV downloads. If you go to the Japanese site on the downloads page you'll see some version 2.02 software that looks like it contains some Chase fixes and the new stuff for the Ethernet card.
PLEASE BE WARNED : I HAVE NOT TRIED THIS OR BEEN TOLD THAT IT WILL WORK! USE AT YOUR OWN RISK!
There is a read me file in the download. Below is the text translated by a free online translation utility ( it's actually worse than a real Fostex manual, image that! ;-)
Contents > of this file < 1.Version past record 2.Method of version rise /////////////////////////////////////1 D2424LV/HET 8360 version past records/ Ver2.Improvement stability at time of 02 modification contents CHASE operation. CHASE adding ONCE mode to mode. Only at the time of ALL selection way the PlayList data of Chain Play saving/it is loaded at the time of the saving FDMS3/loading, modification. Ver2.When using Fetch with 01 modification contents FTP, when the program where prohibition letter is included is drawn up correcting the trouble which continues to make New Song. With FTP the file which is uploaded several frames correcting the trouble which has the case where it slips to the substance. Way TCP/IP setup the value which the occasion where it does is set is reflected automatically, modification. Operation stability improvement of file transfer. Method of //////////////////////////2 version rise/ The equipment > which is necessary for < version rise job 1. Operational verification external SCSI equipment of our company (MO drive and ZIP drive etc.) 2. At DOSFAT16 format entry possible computer and drive and record media * The operational verification external SCSI equipment () list such as MO drive and ZIP drive is stated in the home page of フォステクス. Http: //www.Fostex.Co.Jp/jpn/MEDIA/MEDIA.Html Concerning the file format of the < version rise file > The version rise file is compressed with Zip type. Therefore, after downloading, Windows as for how to use -> -> -> Winzip and the like Macintosh as for how to use -> -> -> Stuff it 5.5 or more, using the thawing tool of the Zip type file of Zip it and the like, please do thawing job just. The file after the thawing please retains at the computer of errand t
The file after the thawing please retains at the computer of errand the route directory of the record media which the DOS_FAT16 format is done (best class). Furthermore, on the disk as does please (either this instruction manual does not retain together in the file other than the version rise file which can be made after the thawing and a state where it does not have the folder, please note). < Version rise job > 1 ID of the SCSI equipment which you use it is good in anything turn, but when it does not operate well, 6th please set to. When HD is made to load to 2 D2424LV, HD (also the second bay includes) please pulls out. Please joint when the power of 3 D2424LV and the external SCSI equipment is turned off. The DOS_FAT16 format disk where 4 version rise file is retained is interposed in the SCSI equipment. Power of 5 SCSI device is turned on first, after that the power of D2424LV is turned on. Recognizing the drive name which is jointed 6 first, after indicating, when it does for a while, as indication of version number appears in the picture, you ask, whether or not it loads the system software, "Sure?" Is indicated. When 7 ENTER/YES key is pushed, the load is started. While loading turning off power of course please does not do every key manipulation. When 8 load ends, some time ago "Sure?" Because it returns to indication, the EXIT/NO key is pushed. The disk is ejected in automatically and "NO DISK" is indicated. The power of 9 D2424LV and the SCSI equipment is turned off. The SCSI cable is disconnected and the power source of D2424LV itself is reentered. 10 version rise is completion. When system version indication when starting has not been different from those of the time before, please try going from manipulation 1 for the second time. When even then it does not go well, you redo from thawing job or, or please redo from download of the version rise file.
wow, that actually is worse than the manual!.
2.02 Is the version I have installed. I've just had a look on the site of the UK distributors of Fostex www.scvlondon.co.uk They've got the software updates for most Fostex recorders if anyone is interested (including 2.02 for the 2424LV).
Thanks for the link. I couldn't find where the software downloads were at though. And hints for the feeble minded? ;-)
