R
role65
Quick listen
Dbl Post!!!!
Dbl Post!!!!
I think it might be a lost cause, it seems there's only a few of us who are interested in developing our ears to become better engineers.
What a disappointing state of affairs.![]()
For me, it's been the act of comparing my mixes to reference tracks at equal loudness that trained my ear. Learning to hear the difference between how the vocals sounded, the drums sounded, everything. Learning what EQ to apply to fix the tracking problems. Learning to avoid solo-syndrome by always making adjustments in the context of the mix. Listening at low levels and playing with compression and limiting is what trained my ears to hear compression and to learn that it's most audible at low playback volumes. Also comparing mixes on different speakers within the control room - cheap computer speakers vs full-range speakers - and learning to hear how poor EQ decisions make the mix change audibly between the two kinds of speaker. Basically, many hours of practising hand-ear coordination until I can listen to a track and hear in my imagination what I need to go in and change to make it sound better. I'm still a good way from having "golden ears" but this is working for me so far.
) consider one of the most important parts of the process, listening to how the mix serves the song. We talk all the time in these forums about "doing what the song/mix tells us to do", yet we talk very little about what that actually means.
), but the indie recordist/engineer often has the task of doing it all himself/herself.First, for Tom: the use of the term "ganged" in association with EQ is a new one on me. I'm used to hearing it used in association with analog radio tuners mostly, or (very generically) with electrical demarcs or junction boxes. I'm not sure what it means or how it works with EQ. I know it's rather off topic, but could you possibly provide a little explanation - or a link to one - of what a non-ganged EQ means and why it's important?
I guess the difference is that I'm primarily focused on the tracks I'm mixing or the songs I'm mastering, I'm not sitting down and spending time writing stuff down (apart from the usual studio log stuff).I'm a little confused. You don't like analytically listening to music, but you listen to every small detail and try to emulate it?
Isn't that essentially a rewording of the same concept? The only difference I can see if whether or not you write down what you hear.
My apologies, midterm grades were postponed a week due to some unforeseen issues (along wth the distraction of the Phils winning and elections). My second engineer and I just finished grading today and I passed out grades for the students 4 hours ago. It would have been premature to post results until they received grades. I have my 4 (out of 15) favs and will be posting results very shortly. Listening to 15 variations of the same track several times can be a bit exhausting.
Part of my goal here is to demonstrate the perspective of a mastering engineer. It's easy to say remix it, and sometimes that's the only recourse to fixing a set of issues, but what if you don't have that option? Are there things that can be done to improve the presentation of the mix? If so, what?
Tom, is there any chance of uploading one you personally didn't like for comparison? Obviously your professional discretion may be needed and if that creates a conflict I understand. I just thought it might be interesting to hear the differences...
Doh! That's easy enough. Lot's of limiting amps/compressors set up that way also. I should have been able to figure that out; I'm surprised I never came across that use of the term...or maybe I did but the Alzheimer's is kicking inGanged is synonymous with "linked" where you are able to change the EQ setting in one channel and the same settings are applied to the other. With non-ganged the channels work independently. The Weiss EQ1 for example has a switch for this.
.....wait, what was I talking about again, and who is this "Tom" guy???or maybe I did but the Alzheimer's is kicking in.....wait, what was I talking about again, and who is this "Tom" guy???
G.
But what I still find lacking in this conversation is something that I personally (FWTW) consider one of the most important parts of the process, listening to how the mix serves the song. We talk all the time in these forums about "doing what the song/mix tells us to do", yet we talk very little about what that actually means.
For me it means one hell of a lot more than *just* balancing the mix in the various aural dimensions, or making it "sound good", though those are very important. And much of what it means to me blurs the lines between engineer, producer and arranger. In a more professional environment those lines may be more rigidly assigned, but for the home recordist or indie mixer, those three roles are often all embodied in one person anyway. And the difference (for me) between an adequate mix and a great mix is one where you can't tell where the arrangement ends and the mix begins or where the mix end and the production begins. The pros know how to work together to achieve this (sometimes, depending upon just how pro the pros are), but the indie recordist/engineer often has the task of doing it all himself/herself.G.
The point of that illustration is to give one example of "doing what the song/mix tells us to do", even though it still doesn't explain how I decided to do what I did. All it shows was that I wasn't prepared to accept the material as it was, and to look deeper into the content (lyrically and musically) to find something to highlight in a musical and engineering way.
I think gecko understands fairly well where I'm coming from with this angle of the conversation, and with apologies and respect Tom, I do believe that it is an important aspect of critical listening to be able to recognize and identify the use (or the lack) of such production or engineering choices.Great post gecko, but it seems that you are speaking more to artistic production than critical listening (and possibly another great thread *hint*).
I won't put words in Glen's mouth, but the term "having the mix tell us" (at least when I've used it in the past) means to let the mix breath and be it's own entity with you reacting to it rather than imposing your will on it sonically.
.it seems that you are speaking more to artistic production than critical listening .
