J
jonasvugt
Hello everyone!
This is my first post, but I've been reading this forum quite a lot to decide what equipment to buy for my very simple home-studio. This is really a great site! I decided on the fast track pro. I've read that there are some bandwidth limitations with usb devices, but I figured it wouldn't be much of a problem for me, because I only want to record one track at a time.
I received my Fast track pro almost two weeks ago and after hours and hours of searching on the internet, tweaking my computer and XP I still have a very annoying problem when I record something. I hear these ramdom crackles. Playback and monitoring (on the decive) work great, until I press the record button. And I really tried (almost) everything. Now as a last resort I have some options left: change my motherboard, buy new (better) RAM or change PCI Latency settings. Because I'm on a small budget I would like to try if setting the correct PCI latency will fix the problem. The only thing is: all posts I've read regarding this subject are about PCI Audiocards.
My question is: What are the (more or less) correct PCI Latency settings for USB Audio? On my tweaked system I disabled all devices I don't use: the ethernet card, onboard audio, parallel and serial ports and also the USB ports I don't use. When I open Powerstrip I can change PCI latency settings for these devices: Two USB Controllers, IDE controller and Graphics controller.
This is my computer:
ASROCK K7VT4A+ (VIA KT400A)
AMD XP 2600+
512 mb RAM
40Gb @ 7200RPM and 120Gb @7200rpm (NTFS)
NVidia FX5200
Windows XP SP2
I really hope someone can help me out. Thanks in advance!
AMD XP 2600+
512 mb RAM
NVidia FX5200
Windows XP SP2
If I were you I'd try to approach the M-Audio Tech-Support to see if they know of anything. It certainly doesn't work as it is supposed to... If they can't help I'd say the next thing would be to take it back to the store to see if you can get it replaced with something that works on your setup.
