D
dogbox
Hi guys, tried connecting the u24 to a motorola g54 5g phone. The main issue appears to be the USB preferences, when I plug in and OTG adapter the preferences stop being greyed out. USB controlled by section has 'connected device' as the default setting, and i need to change to 'This device' .(don't I??).. Below that it has settings under the USE USB for: File transfer, USB, USB tethering, Midi, PTP. i have used developer options>USB configuration I have tried changing to all of those settings, to no avail...in the hope that the g54 will be the master device...i would like to solve that issue.
Bottom line, I believe because of the usb issue.. I can't get a stable connection in N-track and FL studio mobile... FLS sometimes recognises, then forgets the device, has to be reset to default...playback is glitchy mis mastched sample rates...an unusable mess. In n-track slightly better results, i can record audio but get no playback...disconnect the device use the phones headphone jack and audio that was recorded is ok...but i can't do music that way. Anyone got something to try...i have run out of ideas.??? got the latest firmware on the zoom, android 14 on the phone...over it. this is my first attempt at doing music on android...not loving it so far. haha
