Bristol Posse
Okey Dokey
I have a shitty P4 and i have already swapped out to a slower CPU fan and that helped alot, but after quieting the CPU fan, I began to notice these really high pitched whines. They are apparently coming from the CPU and the HDDs.
The machine is on the closet floor with decent ventilation when not recording it's not covered at all. Just sits in the closet with the door closed. The back and front are not covered.
No what I need is a new machine. The new processors and case are really quiet, they can run alot hotter than the P4s. But not interested right now, especially since my PCI card doesn't fit in most new motherboards.
CPUs don't make any audibe noise. CPU fan should be the only noise coming from that area.
If you are hearing high pitched whines from your HDD. backup everything now and prepare for a crash
Newer 45nm CPUs such as duals, quads and i7s actually run much cooler and more efficiently than P4s so there is less fan noise even from an intel stock fan
What kind of PCI card are you using that doesn't fit into a PCI slot. A PCI slot is a PCI slot and is no different now than 5 years ago. Most current MOBOs have at least 1 PCI slot as well as PCI/E and PCI 2.0
The only thing I can think of is a graphics card using non PCI interface which has been largely abandonned a long time ago
