J
jalbert
I have a Marshall AS100D that I'm going to hook up to a small PA system for a live gig. When I've tried running either the DI out's or the LINE OUT's into a mic input on my tapedeck the sound is always horribly distorted no matter what I do. Will I have this problem when I plug into the PA's mixing board? What kind of input does the PA need for the signal from the amp to sound good? Should I use the DI's or the LINE OUT's? Also, I'd like to possibly run a line from one of the amps out's into a digital recorder. Will I have the same problem doing that as I had with the tapedeck? Thanks.
