JBr33zyMusic
What would I need to connect this Studio Projects VTB-1 Single-Channel Microphone Preamp w/ Tube Blend to my Alesis multimix 6 usb? Thank you!
Output to input. Just like anything else. In your case, LINE out to LINE in.
The preamp has balanced (TRS) 1/4" and XLR outputs, but the Alesis does not have a balanced 1/4" line input section, so use standard 1/4" TS cables. You can use TRS cables if you have them already, of course.
Don't use XLR to XLR cables as then you will be putting the pre-amped signal into the Alesis preamps.
