poopchute
I recently bought a Hantek DSO5072P Scope to use for aligning the heads on my Tascam TSR-8 tape machine. In my manual it just says to connect the outputs (2 & 7) to the scope. But Im confused if I just try to clip the probes right to the female rca plugs on the back of the TSR-8 or should I use an RCA cable and try to connect that way? Or use alligator clips? What is the proper way to connect the RCA outputs of the TSR-8 to the probes so I can check the signal?
Thanks
Thanks
