It depends on the intermittent sound you were talking about,...
and keep in mind that the cabling is absolutely the first place to begin troubleshooting, but if you exhaust that, you may end up troubleshooting the audio cards. It's an advanced level of troubleshooting, beyond the cabling.
There's sometimes a value you'll get by removing the plug-in component, in this case the audio card, and reseating it into the mother board. Sometimes card seating is an issue, or the quality of connection may be less than 100%.
There's about 8 little multipin connectors at the bottom of the audio card, and you'll have to take the utmost care when removing and replugging these cards. They may be in there pretty well, and they may seem like they're not removable, but believe me, they are removable. You just have to grasp it tightly, and give it the best straight outward tug or pull that you can muster. There's a very minimum of rocking or uneven pulling you may do to get the card out, but don't get carried away with it. A lot of it's in the fingertips.
Re-plugging the card should be done carefully, to ensure all the pins and connectors mate properly, and then just seat it down with adequate finger pressure, as you'd seat any other pluggable circuit card. Make sure all the cards are evenly inserted and level on the edges.
If you have an intermittent signal, beyond the cabling issue, you may want to check and/or reseat the audio cards. If this does not resolve the issue, then you may want to remove the channel card of the faulty channel, and swap it with another card position, to see if the problem stays with the slot, or follows the card.
These are a few ideas on how to proceed troubleshooting this problem.
If this troubleshooting reveals the problem stays with the slot, then you may have a weak solder joint on the mother board connector. If you find the problem follows the card, then you may have a connector or relay problem on that card.
Jfyi, the audio relays on the audio cards are a component that sometimes go intermittent, with a definite sputtering sound, probably similar to what you're describing. In some cases, a thorough daily warmup and workout of the deck is enough to regenerate the relay function, switching many times between input/sync/repro. In some cases the audio relays may ultimately need to be replaced.
Start from the basics, & work out. Try to cover everything thoroughly in troubleshooting, and don't get ahead of yourself. There's a handful of things that can cause an intermittent dropout or sputtering of a channel. That's just a general summary of tips.
