T
The Ghost of FM
Banned
Hey Billy,
Glad to see your coming along with the recording/orientation process and seeing all the new possibilities!
As for your question;
If the guitar amp's headphone jack is a stereo out plug design and you plug in a standard two conductor guitar cable, you will short out half the headphone amp circuit on the amp. Not good!
Better, still, try a cheaper DI box which has a 1/4 inch input and a balanced output and plug the balanced out of the DI box into the balanced mic input on the board and adjust the trim control for unity gain on the channel strip.
I picked up a DOD DI box for $20.00 a few years ago that sounds great and solved alot of problems I was having trying to record my Gibson SG and Electric bass guitar. Best 20 bucks I ever spent in the studio actually.
Once you do get the guitar amp situation straightened up with the longer cables needed to run it over to a padded closet or similar isolated environment, you will probably end up liking the mic'ed cabinet sound even better then the DI method.
I expect as well that the headphone out from the guitar amp won't sound very good and you might as well try just plugging in the guitar straight into the board as well as a test and forget about the headphone out.
Experiment and see!
Cheers!
GO CUBS!
If the headphone is a mono out plug, you could try it at a low volume and plug the other end into the line input on the M312B but, I would stress the warning about keeping the volume low on the amp at first and dialing it up slowly until you get a respectable signal on the mixer at unity gain, ( channel fader at the hash marks & input trim for line input at 7 on the trim knob at the top of the input strip), again.So if I run my amps Headphone Out into a channels Line In will I destroy anything??
Experiment and see!
Cheers!
GO CUBS!
