mutt
I'm trying to get some info on two things:
For our live performance rig, which is:
12 channel DOD board, routed through a Rocktron effects unit, signal sent to the Soundtech monitor amp on monitor outs, and signal sent to DOD eq unit before going to Crown power amp. We mic 4 vocals, 3 instruments, and the Yamaha electronic drum set.
1. Compressors - what would be the right type of compressor. Would one compressor unit control everything that is miked? How is it set up in the sound chain? (between the board and eq unit?) Can you assign the signal to route to the compressor via an effects send, so that each channel can control the amount of compression? (As you can tell, I know NOTHING about compressors)
2. Hum eliminator- Is there a hum eliminator on the market that can connect to the main power source for our entire rack (board, main and monitor amps, effects, and eq unit) or do you have to have a separate one for each piece of equipment? Or, do you generally connect the hum eliminator to only the board?
Again, do you recommend any particular hum elim. that would be right for our rig?
After our last gig of having "a certain person's voice" setting off the feedback and overpowering the mix regularly, I think we need to look into a compressor, or something!!@!@!
mutt
mutt
