J
Jeremy Muller
Trying not to beat a dead horse, but...been doing a lot of reading on compressors. Thought I had a small clue. Began compressing some vox. Okay, got some results. I have been following some presonus guidelines for using compressors. Why does Cubase Le4 compressor not have settings anywhere close to these guidelines? Examples: suggested setting for attack on different types of vox is .002ms (that's two-thousandths of a millisecond). Cubase only goes to 0.1 (one tenth). However this is not labeled as ms or anything else. Would this be something other than ms in Cubase? Similarly, threshold on a mix setting was threshold of +5.5dB. Cubase goes to 0.0dB. Although not labeled as dB. Also, ratio suggested at 10:1, Cubase goes to 8:1. Now this last one may make sense because at 10:1 I could use the limiter instead of compressor (right?). So I am wondering about the limitations of the le4 compressor or if I am comparing wrong units or something.
Finally I was trying to compress a stereo mix of multiple channels. I had a threshold of -1.6, ratio of 7.1:1, attack of 0.1 and release of 98. Okay. The input level was +4.3dB, yet the gain reduction was only -0.4 for a final output of +4.0dB. huh? I thought I understood the math, at least to a degree where the numbers would make a little sense to me. Am I just really lost in my understanding? Any help and I'll name my 1st born after you...well, maybe a pet. Thanks.
