First, as pointed out by others, a limiter will not do what you are talking about. You don't need a bunch of mics, you need 2 or 3 good ones. I've recorded choirs with some success using a spaced stereo pair (Studio Projects C-4's), coincedent (Neumann KM184's), M-S (AKG C414B-ULS and Neumann KM184) and with a Decca Tree (2 C414B-ULS and one B.L.U.E. Kiwi). A Decca tree is basically a triangular array of three omnis, which can rock on choirs if you can find the right place to put it. In no case did I use more than 3 mics, and in general, the mics were a good 20 feet or more from the nearest choir member.
As far as dynamics, my rule of thumb is that the live performance will peak at least 6 db higher than the rehearsal, because of the net effect of adrenaline. The more professional the group, the smaller the difference. The Boston Pops will stick to the plan, but a bunch of high school kids on adrenaline can be scary. I simply don't use compression on classical music going in, I'll track lower, and compress and boost gain later as needed. There are some exceptions to this, such as "Mars" from "The Planets", and the 1812 Overture. When they start using cannons, all the bets are off!-Richie
