Re: how?
hottsauce_21 said:
how can i EQ my vocals with Cool Edit Pro?????
One word....
CoolEditForum
Just kidding...
select the vocal track (highlight)
right mouse click and select "Edit Waveform (at the top)
this will select that track only for editing.
Be aware that once edits are saved, they are permanent.
You might want ot loop duplicate the track in Multitrack view...
drag it down to an empty track....then right click and select "make a unique copy...
this will give you two tracks exactly the same...thereby you can edit one safely and still have an original for future use if need be...
If you do not make a unique copy....the effects applied will transfer to both the original and the loop....
I regress,
Once the track is in Wave edit view, you can apply effects such as compression in the dynamic processing selection under Amplify
Edit
Amplify
Dynamics processing
There are a lot of presets for compression here...
there are also many other effects and filters such as the graphic equalizer under filters
Edit
Filters
Graphic Equalizer
Good luck,
Joe
