X
xstatic
It seems to me that the biggest problem here is that you guys are using the mixer in a way it was not really designed. Main outs are fine to record off of, but are not designed to do that when also needing playback. This is why recording consoles have direct outs and buss outputs. Direct outs are usually used for raw channel outputs while group outputs are used when more processing is desired on a record channel. This also facilitates easy monitoring. I do not normally like to do the insert plugged half way thing as a direct out, bt it does work. Returning the M-Audio to a channels instead of a tape return and sending from the insert point will greatly simplify and increase the capabilities of recording, monitoring in headphones, bussing and running control room speakers.
