K
Kye Zaeta
Hello All! This is my first post here so sorry if it's already been answered or in the wrong section.
I have a Blue Yeti Pro, a Focusrite Scarlett 2i4, and a dbx 286s. I have it connected: Yeti (XLR)--> dbx (Line)--> Scarlett (USB)--> PC My question is, how do I balance the gains on all of them?
Anything I'm not sure about I usually just keep in the middle. But with the Yeti, it's just too loud. I keep the mic gain at around 25%.
https://i.imgur.com/tS8VlHi.jpg
If I had it at 50% I'd have to set the line gain on the dbx very very low (not sure if that's a bad thing or not, but I'll assume it is until told otherwise).
Next is the line gain on the dbx. This one I actually know a little about. The level should generally be below zero or at zero when speaking very loudly. This one I'm pretty confident with.
https://i.imgur.com/2GDkkvc.jpg
However, if I need to adjust my microphone gain, I would also need to readjust the line gain as well.
Then there's the output gain. I really don't have a clue with this one.
https://imgur.com/V4w3ogy,tS8VlHi,2GDkkvc#0
All I know is that the signal shouldn't clip. So I set it just below the point where the clip light flickers.
Lastly there's the Scarlett gain. Now I know that I basically have a secondary unneeded pre amp, but I need a medium for the audio to get to my PC via usb.
https://i.imgur.com/xOnzb6t.jpg
Obviously this should be set so that the audio doesn't distort while recording in-application, so this one isn't such a worry either. But this one is also dependent on the settings of the other gains.
The two main ones I'm confused about are the mic and dbx output gain.
Any help would be appreciated!
