ido1957
9K Gold Member
OK, here's mix 2.0
Changes:
- Overheads hotter
- Kick emphasis moved from 64Hz to 80Hz.
- Under snare mic hotter, has some 'verb now
- Top snare mic a smidge hotter, but some low end pulled out
- Vocals run through mild (30ms down the left) stereo delay, a tad hotter
- Master stereo mix rolled off at 31hz a bit, pumped at 6.3KHz a smidge for clarity.
- Bass guitar upper mids that had been pulled got rolled back in a bit
- Right side guitar has edgier EQ curve
- Lead guitar has a smidge of delay
Better mix overall. The verb and delay are a good addition. Adds some dimension/bounce, but it might be too wet. On headphones the delay pushes the vocals towards the right side, maybe too much? The snare drum sounds a little brighter to me. I'd suggest rolling off some of the highs on the lead guitar - the delay works the same as the vocals but is good for the short time it lasts on lead. I need to listen to it a few more times to get a better feel for the changes but I think it's better (even though the first mix sounded great in it's own way...
