simajanpa
I now own a Yamaha MD8 recorder. I use outboard gear now(compression and reverb) since it has none built-in.
I usually record my tracks WET, and add a touch more at mixdown. I also use this machine as a mixing board (at home)
to practice with. (keyboards+mic+CD)
My question is, IF I choose to buy a Yamaha AW16G, can I still record my vocal signal WET, and/or practice with this setup and have the monitor mix be WET. The way the ad reads for the AW16g and other similar units, it appears that you can only add
the effects AFTER you have recorded your tracks. I can't
imagine this is true. Can an owner of this type of DAW please enlighten me?
Thanks
Paul
Thanks
Paul
