Here you go:
http://www.mediafire.com/?ib8vyyad2rrp9li
Just download and unzip, there are several .wav files.
Let's see...
I only did vocals for right now, as that's what you were interested in.
All tracks were recorded with the mic's low cut switched on.
There is an air conditioner intake in my room that I can't turn off, and the filter helped clean up some of the rumble from it.
There are three takes done in the full cardioid setting, three done in the setting midway between cardioid and omni and two done in full omni.
The hard/soft distinction is made between whispery vocals and ones done at a normal speaking/singing volume.
The close(near)/far distinction is between being right up on top of the pop filter and being a stretched hand's breadth from it.
All tracks are unprocessed, save for normalizing all of them. I just did this as the absolute quickest way to sort of volume match the various samples. Lazy I know, but it's also free.
Import them into your DAW and fuck with them if you want them RMS matched.
That should be about it. Any questions or suggestions for further samples of things you'd like to hear, let me know. I'd be glad to within reason.
