T
theBrooke
Ok, I will start by letting you know I am a newbie as far as recording... Hope that didn't scare to many people off
I have a g4 running 10.3, audiophile 2496 and I am trying to conquer a very simple task (I thought) to start with. I have a signal going into the analog ins and I want to record it. I have the patchbay setup so I can hear the signal through my monitors via the soundcard so I thought that meant all was well. When I open up my recording program (in this instance spin doctor 2), and record it does so but all I end up with is a loud constant static noise. I read the f*cking manual, no help.
Any ideas/ suggestions from those more educated on such things? Rookie mistake?
***********thanks
***********thanks
Brooke
Got it working... Had to install another program like you said. Not sure why the first two don't work, but at this point fuck it. I ended up downloading Bias Peak 4, so easy worked the first time. Only problem is after 14 days, I'm supposed to cough up $499 for the bad boy. Ouch! That would definitely leave a mark... so I'm looking for a creative solution to that problem now. Any suggestions? Direct them at my email
