		skycanyon
I'm using the first-version ART Digital MPA as a preamp to record vocals. (The mic is an Audio-Technica 4040.) When I followed instructions to set controls at a default level, I couldn't get the predicted response. The manual says:
"Start by turning down the Input Gain knob and centering the Analog Output knob. Use the analog meter to view the operating level by depressing the switch under the center of the analog meter. The meter will now indicate how much tube headroom there is. [None of the switches under the meter do anything like this.] Set the +20dB switch to the out position. Increase the Input Level knob until the meter reads above –10dB. If you have turned the input knob fully clockwise and the indicated level is still below –10dB on the meter, center the input knob and depress the Gain switch. Increase the Input Gain until there is sufficient level. This procedure optimizes the gain elements to provide the widest dynamic range possible."
For one thing, no knob cranking I tried would budge the meter needle. Not even cranking up all gain and output knobs. And pressing the +20dB button.
I finally set gain and outputs at 3/4 and then created a conversation-volume signal near the mic. That moved the preamp indicators to the expected levels. In a subsequent test, Reaper recorded this input as expected.
Before I go charging ahead with my workaround, is there something I should know about this deviation from the manual?
