D
doulos24
As to your first couple points, it isn't ANYTHING like analog summing. The analog outs of the 001 are being converted back to digital the instant they hit the dm24, so the fact that they are "analog" across the cable is pretty irrelevant (other than adding two stages of conversion for no reason). Also, the summing is the same on all digital devices. 1+1 =2 in PT, Cubase, Reaper, etc. Can't change that fact. Besides, the addition is already done BEFORE it goes to the output D/A and the S/PDIF. Both signals are 100% the exact same bits. That's what makes digital so great. In analog, every path the audio goes through changes it a bit.
the reason is there is no way around it to use the extra channels it only has 8 adat and 2 spif outs I needed 12 thus I had to use the extra analog outs
otherwise I wouldn't have
there is alot more to summing then that it's also how the bits are rounded off like for example the first 59 tracks in pro tools mix are fixed 48bit and the rest are rounded down to 24bit they sound diffrent and thats the same program!
I think there are subtle diffrences in the mixdowns of the diffrent daws and I know about null tests, but in my experience there is a diffrence
