Yes, as Harvey has said the ribbons are probably the simplest and most elegant mic design. What fascinates me the most with them is that with all their simplicity of construction, they are in fact, probably the most difficult to design. The whole thing is full of compromises, and trade offs. Let’s face it—almost none of them have the HF response even close to average condenser—that’s why everybody describes them as “dark sounding”—whatever it means.
Theoretically, because of low mass of the ribbon, they are capable to go at least to 50Khz(!), but in reality, it is at the best…. well, depending on the design.
In velocity type you want to get them go higher, so the baffle (the “wings” around the magnet) should be smaller, as the force on diaphragm will be canceled at frequencies when the wavelength is equal to the length of the signal path between front and rear of the ribbon. In other words--the smaller the path—the shorter the wavelength—the higher the frequency. At the same time, the smaller baffle means that pressure difference built up between front and rear is much smaller at low frequencies, so we get loss on low end, since the ribbon becomes more resistance rather than mass controlled. At the same time, the smaller baffle means smaller magnets, or pole pieces, which reduces the magnetic flux, and thus sensitivity of the mic.
There is number of designs to overcome some of these—for example Coles, which uses smaller pole pieces, and additional baffle, made out of porous gauze with low acoustical resistance to compensate lows. Also, there were other designs, which are still full of different kinds of compromises. WE and Altec, with their dual—velocity ribbon, and dynamic omni capsule, which then were electrically combined for different patterns. Some designs with horns, tuned to high frequencies. Unidirectional RCA 77A, where one half of the ribbon is velocity, and another—pressure type, with closed chamber behind, and sofisticated acoustical labyrinth—actually I like this one a lot. In addition, they have quite uniform directional pattern. Ooooops, just got an idea... Huh, enough for today.
BTW, did I mention their output? OK, time to go to sleep.
Oh, and I almost forgot—I just love ribbons!!! Aren’t they wonderful?
