M
Move-over-Kate
My ATR-1 used to work fine, I never had any trouble with it. It remained "on" continously in my rack over several years. Now I wanted to use it again after a short while, and I've got a problem:
The ATR gets an input signal, the signal level meter works - and I get an output signal that I can hear over my monitor system. I guess something within the ATR seems to work, because when I listen to "original" signal and "ATR-signal", I hear a kind of phase shift, like a slight chorus... But the pitch correction does not work anymore, even the pitch change meter does not react. It seems to me that the ATR is switched "Bypass" all the time, even if the bypass-button is not pressed and the bypass-LED is not lighted.
Any suggestions?
Any suggestions?
This unit even has no power-switch - it is meant to stay in stand-by all the time. Hope the Antares' guys can help. Perhaps they should equip their units with power switches to avoid problems. Greets from Germany...
