Sorry about that. The actual URL is
www.nowhereradio.com.
Aaaah, I took the link literally
That's a neat trick you did with the 505. I'm happy about getting the 707. I can use all of the outs to lay a stereo drum track by bussing on the console and adjust the volumes of the individual drums.
Thanks
I really didn't need the indivual outs for every drum, even though I soldered it up. I did this primarily because I wanted a stereo mix, and the snare seperate, so I could add a little flange for a specific project. Originally, I panned all the drums left, and the snare right, and achieved the same thing, but the overall mix of drums wasn't stereo. Since that point, I've tried to purchase drum machines that had seperate outs. My Kawai R-100 has this,
the Akai XE8 does, though my DM4 does not. So, I fire off a snare from one of the first listed units and use the stereo mix of the DM4
I might record separate tracks for the kick, snare and the rest of the kit too. I haven't worked out the arrangement for the next song I'm going to record, so I'll have to see how many tracks I'll be using.
For non-techno/non-dance music, I could easily spend hour after hour playing with pans trying to get the kit to sound the way I want.
Anyway, someone asked earlier what one uses for a drummer... since my home studio is tiny and requires humping drums up a flight of stairs (through the vocal booth floor) I simply set up a double set of old simmon's pads, connect them with patch cords to a Roland PM16 (I think) as well as a Roland Ocatpad's external 6-inputs, then merge the midi information together into one midi track. Then after the fact, I can edit, change patches, kits, etc. For more rigid timing I can quantitize it (for techno, dance, rap) and for rock I can usually leave it the way it is based on the guest drummer we often use, and for jazz I can do the reverse of quantization and shift things a hair forward and back for a little more "feel" than our rock drummer often gives us.
This allows me more flexibility, and the drummer only has to bring his favorite throne and sticks
And the simmons pads were dirt cheap on e-bay too. A full double bass setup with about 15 tom/snare/cymbal pads cost us less than 200 dollars. Had to make my own stands however, which I used ordinary PVC for. Total bolt together. Takes 20 minutes to set it up, and about the same to tear it down. For wiring I patch it into a 32-channel snake I lay across the floor to the patch bay. Almost too easy.
