Dr ZEE
Anti-Pro Circles Insider
Sounds cool! Then you are all set, sort ofTrack Rat said:I've done some investigation. Preamp looks like 12AT7 and 12AX7, two 6V6's out. As soon as I turned it on I can hear a lot of 60 hz hum. Looking inside, I found that the tone arm electronics plug into the amp on a single RCA. I cobbled together a 1/4" to RCA and plugged in a guitar. If I can get rid of the hum, this will be a kick ass amp just as it is.
Now about hum. I really can't clearly point out how to deal with it for sure 'step-by-step'. If I'm not mistaken, some hum may be sort of normal, but it should not be terribly unacceptable.
My experience. When I turned on that last webcor machine it was totally unacceptable. Not just hum, but all sorts of ugly sounds. So, in my case it was the load of problems , I suppose. Since I was planing on complete re-design anyway, I've decided to replace all electrolytic caps, all coupling caps and all cathode resistors bypassing caps.
To give you a general idea, I've made THIS CHART - CLICK TO VIEW (better see one time than hear many times
)I would say you need at least to replace power supply filter electrolytic multisection capacitor. Would it be enough or would it be just what needs to be done in your case - I can't tell.
If you are going to try fixing it, again, be careful and follow safety measures.
I've ordered capacitors from W J O E RADIO - click to go to the page
I've found that man via e-bay actually, have contacted the seller and he said that he has various components for sale. I can recommend. Got my caps fast, the price is just fine from what I've seen around. Also, you can e-mail contact him with specific question about your unit and maybe get an advice.
OK, what else can I say. Fixing an amp like that is not very hard (assuming you've got bassic knowledge, ok soldering skills and you can discipline yourself while working (these are not toys
)), but still , messy, takes time and all that. Good luck if you do. Post an update.********
LINKS:
Here's a well put page about draining electrolytic caps: How To Drain Filter Caps (Fender DeVille/Deluxe example)
Tube Amp Overhaul (capacitors)
Replacing Passive Components to Improve Sound Quality (by Paul J. Stamler)
