Z
zelmobeaty
If you own both Acid and Sound Forge, is there any good reason for using the effects plug ins directly in Acid?
Doesn't it save processing power to export the files to Sound Forge, edit, and then open back in Acid?
Another question:
Say I edit a vocal file in sound Forge with compression. Then when I open it back in Acid for my final mix, I decide i don't like it. Is the first compression setting permanent? Or can I open back in Sound Forge and change the compression?
Much obliged.
Another question:
Much obliged.
