F
foggie
EDIT - Absorber const/placement/faced or unfaced
EDIT - Sorry, I had the two year old climbing on me and the five yr old asking me fifty questions when I was trying to post this initially
AND I figured out how to link the images etc..
Thanks Ethan for your response. I have read most of the info from your sites and has been EXTREMELY informative - Thank you
Again, I just need some clarification.
In reading about making absorbers I have a few questions. I have a pretty small area that I want to tune up (13x12x7.5’). The area is used as a drum room and will be adding daw setup to record as well. Pretty reflective room (wood paneling walls, sheetrock ceiling, concrete floor.
Questions:
- I know 4” is ideal but should 2” 705 be used in all the corners as opposed to 703? I can get them locally for $15/ea and $10/ea respectively with shipping $10 for a box of six
- Should the corners be floor to ceiling “frames” (e.g. 7’x2’) or can 4’x2’ frames be used centered in the corner?
-What frame/construction method would be recommended for the corners, walls and ceiling (see trap pics) ? Consider the small space.
-Should faced be used, if so where (corners, walls, ceiling) and what direction?
-Would removing the closet be a benefit acoustically (obviously it would provide more space) see room layout pics
trap 1
trap2
trap3
layout 1
layout 2
layout 3
layout 4
5MB exe that is a self contained 3d model of the room. Download it and double click it to run (doesn't install anything)
http://cid-57bc9f50beb41656.skydrive.live.com/self.aspx/Public/Studio%20CAD%20layout.exe
AND I figured out how to link the images etc..Thanks Ethan for your response. I have read most of the info from your sites and has been EXTREMELY informative - Thank you
Again, I just need some clarification. -------------------------------------
Questions:
trap 1
trap2
trap3
layout 1
layout 2
layout 3
layout 4
