...If you're talking some starved-pate unit with a 12AX7 which would probably sound exactly the same if you replaced the tube with some carefully placed bent paper clips, then it's probably worth a shot.
That all said -- If you're coming up with nasty, microphonic, inconsistent tubes in the first place, I'd start with contacting the vendor.
I see a business opportunity, there...
   And, yeah, I'd be sending those puppies back WHOLSALE if I got a whole batch of tubes I didn't like.
Almost all pre-amp type tubes are microphonic, to some extent (I have read this, do not know it from personal experience except to say my experience supports this.)  AFAIK, there is no bench/electronic test to determine a tube's level of microphonics- the only test I know of is the "tap it with a pencil and listen" test, which, given the microphonic quality of all such tubes, rather subjective and thus of limited value except in the extreme.
I wonder:  how 'bout a "Microphonic Tube Tester" that would "listen to a tube for it's level of microphonics?  I'm thinkin', a tube socket that powers up the tube in whatever way it needs, and a flush-mount pot (that can only be turned with a screwdriver- no knob on it) for "calibration."   Inside the tester is a little spring-loaded hammer with an eraser head- you pull a lever that cocks the hammer, then releases it, thus tapping the tube with a pre-determined level of force, always the same.
First-time use procedure would be to put a tube in the tester that you "know" is micro- that is, one that has a level of micro unacceptable to you.  While activating the hammer, you adjust the calibration so that that particular tube is shown to bring the meter to "5" on a scale of "10."  Then, any tube you test would be rated, compared to that tube.  It would take most of the guess-work out of determining if a tube was "micro."
Would it work in the real world?
