M
morte sicura
Hi everyone...
This is also posted over at the Tascam.com forum, in case it seems familiar ....
and please bear with me
as I try and get my goods together recording-wise.
As some of you know, I got my 38 a week or so ago and the manual came on Monday - one of the reel tables (right-hand side) was below operating level and I've fixed that. However, a new and perplexing problem has arisen, and though the manual is pretty thorough in describing adjustments, there isn't a "troubleshooting" section to help diagnose problems and point to the proper solution / adjustment.
I tracked a song or two off CD onto a couple tracks and I also set up some drum mics and began experimenting with drum sounds. Also tracked a bit of electric piano at the front of the reel. Everything sounds fine so far.
But - at about 2500 on my counter (with the counter zeroed where I started near the front of my reel), FF has seriously slowed down! It isn't running much faster than Play, and will eventually crawl to a stop, maybe around 3000 or so. Rewind works fine.
Also, although the material I recorded at the front of the reel sounded fine, by this point on the reel, there is noticable "wow" on the tracks. Playback speed is inconsistent and "warbly" sounding. I didn't really notice it with the drum tests, but when I tracked some electric piano in this mid-reel area, the pitch was moving around, almost as if someone was lightly twisting the pitch control. It sounded like an old cassette player when the batteries start to go bad.
Okay, so I have looked through the manual, but as I said, there's no real troubleshooting section. Does anybody have any idea what to look for or where to start in solving this problem? Seems like something isn't right with the right-hand side of the deck.....
Thanks,
Andrew
Thanks,
Andrew
