masteringhouse
www.masteringhouse.com
legacygone said:Thats interesting advice. Most of the stuff I read on here would contradict this.
Not sure if I agree.
I don't get it, what's the punchline?
I thought maybe it was the "not sure" part.masteringhouse said:I don't get it, what's the punchline?
I have the same interface and you turn on the Mic pre's from the control panel. The only thing is, I believe when you plug in an XLR cable the Mic Pre 1 comes on automatically, but you can switch it back to Line. Incidentally there are two settings for Mic Pres on this interface. M1 provides +55dB and M2 +75dB.Cazzbar said:Appreciate replies (even if I have hijacked the thread with my personal woes )
I'm using a Aardvark Direct Pro soundcard and a Peavey RQ2316 mixer... connected using XLR leads. There's no gain knob on the soundcard's breakout box, that's all controlled using software. The gain there is set at '0'.
Jeesh just had a thought whilst explaining this, if I'm using XLR leads to connect to the soundcard.... it might assume it's a microphone and naturally boost the gain. Maybe I need to RTFM again after all these years, but thanks MM for highlighting a problem I've just kinda ignored.
