Shockadelica
I installed my new Audiophile 2496 today. Everything went OK except there is a lot of popping and static coming from it without anything even being hooked up it. The only way I know this is because it registers on the "H/W In 1/2" meter in the Delta control panel even after I disconnect all the cables.
Question 1: What could be the cause of this? I don't even know where to begin to look.
Also. I will be using it (hopefully) with HS2004XL. The problem is no matter what settings I use on the Delta control panel I can't get anything to register in HS. I followed the instruction manual for HS on how to set up a track to record but no matter what settings I use and no matter how hot the signal I get nothing. So far the only sound I've heard with this set up is the noise from question 1. Which leads me to:
Question 2: What setting do I use on the Delta and/or HS? I'm using the RCA in and out connections between the 2496 and my mixer.
I would appreciate ANY help ANYONE could give me. this was supposed to be a day where I lost track of time and stayed up all night recording music. Now it looks like I'll be going to bed early.
I mean, is the noise you wrote of in your original message still there, or is it gone?
I just threw together a few measures to get something down. The noise is still there though. The same as it was yesterday.
