Scotsman
In my research for a front-end incorporating preamps, phantom power and a/d conversion, I've come across numerous products.
One of these is Mindprint's Di-Port, which just happens to be the most readily availalbe and affordable for my needs. I've already posted about that though so I shan't repeat myself and annoy everybody.
The point of this question relates to the bits and hertz. The Di-Port is capable of 24-bits and 96 Hz. My SB Live soundcard is only capable of 16-bits and, as alfalfa kindly pointed out, this would lead to truncation -- which presumably means something like 8-bits will simply be lopped off. It doesn't sound good.
Alfalfa has been a big help in pointing out the C-Media CMI8738 chip which is available on several budget soundcards. I found a fairly good list of cards with this chip here. The documentation for this chip states that this chip supports professional digital audio interface such as 24-bit SPDIF IN (0.5V ~ 5V) and OUT (44.1K and 48K format).
So it seems that I could transfer the converted 24-bit digital data from the Di-Port digitally to the PC without the truncation that would occur with a 16-bit soundcard, but I'm not sure what the 96/48 Hz thing is all about. Could someone explain in simple terms what it means, and whether it would make any real difference to any music I would record.
And in the board's opinion, would the Di-Port and a soundcard incorporating the CMI8738 chip be a good solution for someone with minimum recording requirements?
Thanks
Jock <after days online, just *beginning* to understand...>
Thanks
