1st full session w/3.0, 19 songs tracked
  • Thread starter Thread starter tubedude
Re: Re: 1st full session w/3.0, 19 songs tracked
Teacher said:
i thought it looked more "professional" cuz it looked more macintoshish
"more macintoshish" he says...... I'm ready to puke.
-0z-
Oznim- Is that location a reference to an old Maiden song? :)
I ran Sonar 3 for an additional 6-7 hours yesterday, tracking and mixing with heavy plugs, and still not a lock up, crash, etc.
Seems solid as hell. Occasionally buggy/weird cause there are new features that are turned on automatically that I havent figured out how to turn off yet. Auto crossfades seem to pop up whenever they feel like, sometimes they do sometimes they dont, under pretty much identical situations.
Anyone know the deal with what seems to be two active outs now? THe first one affects the second ones output, seems a little weird.
One is a master bus and one is a main out.
Sonar 3 has a main output section which consists of one fader for each of your enabled soundcard output pairs. There is a bus pane in track view, but no main out pane, so the main output faders are only visible in console view. They control volume to your soundcard(s)... nothing else.
You are probably using a master bus and it operates just like any bus or sub-group fader. New to Sonar 3, output from the busses can be routed anywhere, AND you can insert "sends" to other busses or main outs (soundcard output pairs)... to simultaneously route the same signal to mulitple places.
If you don't opt for importing your Normal.cwt template settings from Sonar 2 during Sonar 3 installation, all tracks in the Sonar 3 default template are routed to a Master Bus which is routed to your soundcard main output fader.
You of course can delete ALL the buses if you want to and just route your tracks to the main output fader, but effects and sends can only be inserted on busses, not main output faders, so the signal path should be track -> master bus -> main out.
If seeing the main out fader bugs you, just right click on it and then select "Hide Main" and it's gone. :) Use the Track Manager to bring it back if you want.
_______
SteveD
www.5adayclub.net/music/
