mshilarious
Banned
SouthSIDE Glen said:dBu is referenced as 0dBu = 0.775 volts RMS into an unloaded (open) circuit.
Well, since Lionel is not here to say it for me, the reason dBu is calibrated to 0.775V, a seemingly random number, is because an even older standard, dBm, is calibrated to 1mW power into a 600 ohm load. That happens to be 0.775V (0.775^2/600). It's leftover from the days when gear was designed to transfer power between 600 ohm loads. These days ("these days" being the last 30 or 40 years), gear is designed to transfer voltage, which means bridging loads, or low output impedance, high input impedance.
So you take the same reference voltage, and say it's "unloaded" (meaning high input impedance, which presents a trivial load), and just for good fun, ramp it up 4dB to +4dBu, which is another seemingly meaningless number in the digital age, 1.233V.
0dBV man, it's only 2dB less . . .
switching to +4 from -10 output on your soundcard while your monitors are turned up is a pretty bad idea
, the idea of tracking at 0dBFS as being a good idea is usually the wrong way to look at it, and, if one follows standard analog gain structre procedure, there's plenty of digital headroom.
